2 members (Dennys28, 1 invisible),
93
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 66 | I did some searching, but did not find any info on big bolt power steering. I'm sure someone out there has conquered this. How much of a challenge is it? Thank you. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | You might get lucky & find a New Design '47-'55 GMC that had optional power steering. I've only seen two of them in the 30 some years, i've owned these trucks. Didn't realise how rare they were then, & didn't pursue either one. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For what year? There are numerous different ways to do it. Take a stroll through a junk yard with your tape measure and see what looks suitable.
I used an IH Scout II steering box and a different axle on my 48. Next time I'll look at a PS gearbox from an imported cab-over truck.
Grigg | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Big Bolt power steering ? 1.5T-2.5T ? . . . I always thought the trick was keep the wheels rolling . . .
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | This would be a lot of work but you might try to find a power assist steering set up off a early sixties Chevy car. The assist works on the steering linkage rather than through the steering box. I had power steering on my 64 impala and loved it. Silk smooth. The hardest part would probably be getting the control unit attached to the pitman arm. And who knows, that control unit may bolt right on a big bolt pitman arm? I have a friend that did a lot of mods on his Scout, and he took two pitman arms and weled them together. I would be hesitant to try that method. If you weld breaks you have nearly four tons of out of control Chevy steel on your hands! It would take some work but if you got it to work you would be a big bolt hero! | | |
