2 members (jay d, Gdads51),
75
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | How many out there are running an old totally unsynchronized, granny gear, 4 speed in their truck?? | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Running one in a 46 and one in a 39. Other than a slight leak on the rear yoke they work and shift great. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | just had the 42 1 1/2 army crash box rebuilt and can't wait to drive it. | | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Ain't they sweet....?
Have one tied to a 261 in a 1940 Chev .... I can do 1 to 2 and 3 to 4 without even double clutching....just by feel and sound..... but the long throw between 2nd and 3rd usually grinds a little. The biggest handycap is the truck is right hand drive and requires shifting with your left hand...Yipes!!!
Like a woman the tranny really behaves best when handled with a firm hand to minimize the grinding.
Bob C.
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Gotta say, love my truck, but not in love with that crash-box! 1941 1.5 ton. If I drove it more often, it would be better, no doubt. As it is, I grind quite a bit, and have to re-learn the sound of the right engine speed to release the clutch after up-shifting.
I'm the opposite of Bob C., though. I find, if I hold the shifter between my pointer and middle fingers, with my palm face-up, it helps me to be gentler, and shift without cramming it and getting yelled at my the tranny.
For me, 1st-to-2nd is a bear. The others seem more forgiving.
I suppose the truck's weight has something to do with it, and my fire truck is likely heavier than most, 'cept maybe for a dump-truck.
-Michael | | | | | Joined: Jul 2010 Posts: 3 New Guy | | New Guy Joined: Jul 2010 Posts: 3 | got one in my '40 1.5t. love it! trying to find another for a spare while i rebuild/inspect, re-clutch the original leaky one in it. cast #590474. i never use 1st, but engage it up my driveway from time to time just to make sure it works. its all about timing between shifts, doesnt like rushing. i drive it daily to work, about 15 mile each way. the most annoying thing about driving, is the others behind that are in a rush!!! most of the time, i get the "thumbs-up"!
1940 Chevrolet 1.5 ton
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I kinda thought there would be more crash boxes out there.
I’m still getting used to mine. My engine is freshly rebuilt so for the first 500 miles or so I hade the idle set around 900 RPM and got used to shifting, but when I dropped the idle closer to 500 RPM it was a whole new ball game.
I like to watch the expression on the person behind me when pulling away from a traffic light. My start is quick enough but the slow second to third shift (I don’t normally use the granny gear first) usually has him right on my rear bumper.
| | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | My '46 with 216 has one. I got the truck in '01. The clutch pedal was set w/ zero free play. I didn't drive the truck much then. It was always hard to start and I'd do a little work on it once in a while and things got hectic with work and I let the truck sit for four years with out even running the engine. In May I started it for the first time and started trouble shooting things little by little. I adjusted the clutch pedal and started to learn the double clutch boogie. Then the water pump went bad. I'm also waiting for the radiator to come back from the shop. I can't wait to get it together again and resume shifting lessons. Jacques
Union, Justice and Confidence
