8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | I am working on a 1952 gmc 2 ton. I just got it running today found out that the radiator leaks very very bad. I have a radiator from a 1952 GMC 1/2 ton sitting in the shop and was wandering if it was the same size as the 2ton. Hoping someone here can let me know. Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if it's sitting right there take some measurements, likely the same mount brackets
Bill | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | I think the big bolt rads are deeper having one more row but otherwhise are the same size. I'm about 75% sure | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 1/2 ton up to around 3 ton will all bolt in the same place. The larger trucks have thicker cores toward the front. It was common for us to bolt larger radiators in pickups 50 years to try to keep them cool. Your 1/2 ton will fit and probably keep the 2 ton cool unless you plan on working it like it was 50 years ago. | | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | Thanks for the replies, i think i might use the 1/2 ton rad for for a short while until i can find a 2 ton rad or get mine fixed. | | |
