| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66970 10/08/2006 11:24 PM | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | after an entire summer with no problems, the cooler weather has given me a project as soon as I figure out what to do! 1948 chevy 1/2 ton with 235 3 speed on the column. one barrel carb with manual choke... In this cooler weather it is hard to get the engine running right. It cranks up with the choke out but if I try to drive it bucks and stalls... smells rich but when I push the choke in it quits... after letting it idle a while it drives fine with choke all the way in etc. got a thought ?? thanks Jimmy | | |
#66971 10/09/2006 12:03 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | You need heat in the manifold to help vaporize the gas until the motor warms up. There's a number of ways to do that, but the basic idea is to get heat to the intake manifold as soon as possible. Some manifolds have water jackets to take care of that, and often the plumbing rusts and people put plugs in the holes, not knowing what their function is.
Sometimes a "heat box" is built around the intake, using metal to form a box around the base of the intake and then feeding exhaust manifold heat into the box using either convection or a tube. | | |
#66972 10/09/2006 12:07 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Here's some stuff on the site that might help: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=008158 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000554 | | |
#66973 10/09/2006 1:47 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | powerband,
On the surface this sounds carburetor related. I would check out my heat riser assembly. I think most of these are frozen open, and if yours is, it might be helpful to get it operational to help heat the carburetor quicker.
It might be a good idea to take a look at the condition of the ignition system. Sometimes humidity and dampness go hand in hand with colder weather, and this can cause a "lightning show" with the cap and wires.
As the engine warms up and things dry out, it will return to normal. Some folks will start their rig at night or in a dark garage to catch a glimpse of the arcing and sparking under the hood. Good luck.
Stuart | | |
#66974 10/09/2006 1:53 PM | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | Thanks for the tips. I will begin with the heat riser assembly... and see what happens. Jimmy | | |
#66975 10/09/2006 10:29 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I have always started my engines full choke and run them till warm 1/4 to 1/2 choke. A heat riser will cause poor atomization of fuel on a cold run if stuck and will allow the intake to warm faster if working. Now if you live in the snow belt the heat riser is important for short drives.
To me the condition sounds normal, if the choke is pulled all the way out and you try to drive it its gonna buck, snort, and smell like fuel. Try 1/4 way out after start till warm. If it isn't better then worry about heat riser.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
