0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#657711 06/27/2010 1:22 PM
Can anyone give me guidance on installing a fan shroud? 59 Apache
1959 CHevy Apache
from a 56, but if you're putting the aftermarket plastic shroud in with a small block, a picture might help ... needs to be so the fan is about half inside
Thanks Bill picture helps a lot, what did you tighten bolts into i noticed that the bolts come out towards block did you drill your own holes?
1959 CHevy Apache
the bolts are longer ones in place of the rad mounting bolts - double nutted so one nut holds the rad, one holds the shroud - shroud can be drilled where ever you want
would a fan with more baldes actually be a good investment as well? Not so much for overheating issue but just more air flow. I am thinking of buying one alnog with clutch just not sure if it is worth it.
1959 CHevy Apache
Squeeze,Great pic. Is that a long water pump on that V8 ?
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
no idea Giant, it's a friends truck and it's whatever pump was right so all the pulleys lined up on the random used 350 he found for the truck
