1 members (55shaker), 117 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#668899 08/09/2010 2:41 AM
ok guys thanks for all the input on the starting problem gonna convert it to 12 volt anyway what is the difference between a h052 and a h072 i am currently running a457 ratio in my truck and just found a 410 but its from a 1969 1 ton drw truck i wanna just swap out the pumpkin leaving the housing alone will this work ??? thanks
hevyft #668902 08/09/2010 2:56 AM
Yes
Steve
'49 3800
'52 3600
'57 3100
hevyft #668903 08/09/2010 2:57 AM
yes they swap out, I know 67-72 3/4 ton automatics had 4.10s so if its out of a 1 ton double check the ratio.
Does 4.10 to 4.57 make such a big difference, I am in the same boat and will be interested to know the driving experience and mileage on that.
Ganesh
Hevyft
You lucky so-and-so. Where did you find it? I've been hunting for a while for my 49 with no luck. Not looking in the right places, I guess.
If it is from a 1-ton and isn't a 4.10 ratio, you may want to hang onto it anyway. Randy's Ring and Pinion (sometimes) has gearsets for 4.10, but they only fit in later carriers. And they COST... Plus the install kit.
Good luck, I hope it's the 4.10.
hevyft #669350 08/10/2010 9:14 PM
The size of the brakes and the gear ratio.
The 4.10 is hard to find and will swap right into either housing so if it really is 4.10 you've a great find!
Can you post exact details of the donor truck?
1969.
Chev or GMC?
Auto or manual?
What motor?
These details may help others looking for this diff.
OldSub #670023 08/13/2010 4:24 AM
1969 c30 with a350 v8 and 400 trans
hevyft #670468 08/15/2010 1:03 AM
smokey_truck
It's right at 90% overdrive or a 10% reduction in RPM at any given speed. So if you have to turn 3000 rpm to go 60 mph with the 4.57 you'll only have to turn 2700 with the 4.10. (somebody check my math) Does it make such a difference is a valid question.
Professional Novice
