Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
c53
Offline
I've followed the procedure in Tech Tips with the 4 inch block, etc. Repeated over and over and spent hours trying to get it right but still not to satisfaction. It all works with good fit, good gap and I'm really happy till the last step. When I hook up the hold up supports, one side kicks out. If I re-adjust the hinges to make it fit the other side kicks out. Never a problem at the top. I'm thinking it all to do with the hinges causing a twist or something, but so far no luck. Any ideas ???
Maybe you have the hinges swapped side to side? The spring should be inboard.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
c53
Offline
Nope, they are inboard, but I was wondering if slop or play in the spring mechanism could be a factor and cause it to kick out.
