0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 75 | I've followed the procedure in Tech Tips with the 4 inch block, etc. Repeated over and over and spent hours trying to get it right but still not to satisfaction. It all works with good fit, good gap and I'm really happy till the last step. When I hook up the hold up supports, one side kicks out. If I re-adjust the hinges to make it fit the other side kicks out. Never a problem at the top. I'm thinking it all to do with the hinges causing a twist or something, but so far no luck. Any ideas ??? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Maybe you have the hinges swapped side to side? The spring should be inboard. | | | | | Joined: Oct 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 75 | Nope, they are inboard, but I was wondering if slop or play in the spring mechanism could be a factor and cause it to kick out. | | |
