| | | Forums66 Topics128,160 Posts1,056,902 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I purchased a replacement gas tank for my 1957 Chevy pickup a few years ago. Now, when I try to install it, the original mounting straps appear too small (no long enough) and the alignment with the filler tube is a little awkward. Otherwise it appears like it should fit. I'm wondering if I purchased a 1955 series 1 tank by mistake. Is there any way to identify which is which? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 49-55.1 tank and 55.2-59 tank ... difference appears to be only on the angle and shape of the filler  Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Bill, appreciate the photos. It seems I have the right one. Now to figure out why the straps appear to be short. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the straps are very tight, only accept very thin tarpaperlike shimming - also I seem to recall the flanges where the straps cross are flattened, maybe not enough on the repro? and maybe it isn't seating well on the floor parts
Bill | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks for the tips, I tried everything (not a lot of options). Still doesn't fit right. I'm wondering if the problem stems from "bending" the straps to get the old tank out possibly deformed them, and in combination with the repro tank potentially not being "right-on." I'm going to order a new set, if they still don't fit, I'll weld in a little extension strapping. Again thanks. | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | Hey Donsz- Just about to do this same thing in my '57- How'd the newer straps work? Any tips/ advice? | | |
