BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (Guitplayer, Possum, cmayna, Joe W, UtahYork, Greg_H, FAST55, rfs56trk),
522
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | Just recently changed my oil and yesterday checked my dipstick and the level had doubled past the Full line. It's like a ghost has popped my hood and poured in a gallon of oil. So I drained some oil out, back to about half full and tonight, just now, my oil light came on in the cab and it's dripping a pool on the ground and it seems to be over full again.
I'm hoping I haven't blown a head gasket and have water from the radiator filling up my oil pan, I haven't noticed a different consistency in the oil and the engine runs fine. Just got rebuilt last year and only has 15,000 miles on the motor.
Any ideas? I'm out of my field on this one! | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | Wrench Fetcher Joined: Mar 2008 Posts: 60 | Check your fuel pump, sounds like its leaking gas in you crank case | | | | Joined: Feb 2008 Posts: 202 Shop Shark | Shop Shark Joined: Feb 2008 Posts: 202 | Sounds like your fuel pump is leaking/pumping gas into the engine. Pull the dip stick and smell the oil, if it smells like gas replace the fuel pump. If it looks milky, it is water/anti freeze.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | When I drained some of the oil, it was dark, but not a milky color. The radiator is topped off for the most part as well. The oil smells very heavily of gasoline however, is this the tell-tale sign?
Also, can fuel go straight from the pump into the crankcase? I know the pump is bolted onto the block but can it go through the block or something? | | | | Joined: Feb 2006 Posts: 649 'Bolter | 'Bolter Joined: Feb 2006 Posts: 649 | Yes!, the internal diaphram will pump gas right into the oil pan. | | | | Joined: Jan 2008 Posts: 4,903 'Bolter | 'Bolter Joined: Jan 2008 Posts: 4,903 | Quit driving it until you get a new fuel pump. It could very well be squirting gas on your cam thereby washing off the lubricant. It doesn't take long to ruin a cam and lifter. | | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | Yea its parked right now, I'm having nightmares of all the scary things that could be happening inside! | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | Wrench Fetcher Joined: May 2010 Posts: 89 | put out that cigarete! drain the oil, pull the fuel pump. get a new fuel pump,fresh oil.and your good to go.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | Joined: Dec 2008 Posts: 1,915 'Bolter | 'Bolter Joined: Dec 2008 Posts: 1,915 | Don't even start it again "just to be sure". Your oil viscosity is now 2, even cranking it will do more damage. | | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | Well, I ordered the pump from American Classic, but I don't know whether to take it into the shop or try doing it myself. I don't want to drive it, but I don't want to pay to tow it, and we don't have a trailer to haul it right now.
Is removing the old one and slapping on the new one easy? I know how to seal gaskets and all that but I don't know if I have to do anything else. | | | | Joined: Dec 2005 Posts: 547 'Bolter | 'Bolter Joined: Dec 2005 Posts: 547 | To change out fuel pumps all you have to do is unbolt the old one, scrap off the old gasket to a nice clean surface. Put in the new gasket and pump. Bolt it down, reattach the fuel lines and your good to go.
58' 3200 235 3-speed/OD
| | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | Ok, so i understand there is some sort of hole in the block where it mounts up, when I unbolt it from the block will oil from my pan start pouring out of the open hole, or is it high enough that it's up past the oil level? Need to know if I should prepare my driveway for trouble or not. | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the oil level is never above the top edge of the pan, somewhat below it actually - the only time you'd get oil out the pump hole is if it was running .... just don't start it with the pump off  Bill | | | | Joined: Apr 2008 Posts: 211 Shop Shark | Shop Shark Joined: Apr 2008 Posts: 211 | Hahaha thanks Bill i'll keep that in mind. And thanks to everyone else who has replied and helped me out on this, I will update when the surgery is over with! | | |
