| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | hey newbie here and man I have questions! Is pertronix the best upgrade for electronic ignition? is there another option to use a spin on oil filter? is the generator 6 volt or 12 volt? do i have to make my own alternator bracket? I love this truck!! 1960 shortbed fleetside with all of the original art deco chrome trim and it even has the jack under the seat. BONE STOCK! thanks in advance.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Your truck has a 12 volt system. Pertronix is a good idea if you don't want to mess with the points. Can't help you with the oil filter or alternator bracket, but that generator should be okay for you unless you want to add a bunch of electronic accessories.(A plus is that they are simple to work on yourself and cheaper to fix than an alternator.) BTW, welcome to the site. Hopefully someone with more info will come along shortly to put you one the right track. | | |
