0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I purchased new shackles for the rear cab mounting. The shackles came and the were not right and left so I had to redrill holes for one side to make it fit to the frame. I am now trying to mount the cab to the frame. The shackles are too wide to fit up in the rear frame mount. Do I have to take the shackles apart and grind off the sleeve to make the shackles narrower to fit up in to the rear frame mount. It appears I do. The only other thng would be to put spacers between the floor and the top of the shackles. I do not have the old shackles to compare the width
Bennie | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I do have the late mounts as in your picture. My problem is the mount is too wide to fit into the rear mount support as it does in your picture. What is the overall width of the mount you show in the picture? Mine are 2 3/4" wide not counting the bolt head and threaded nut. I bought the complete shackle because my old ones on the truck were in too bad of shape to rebuild
Bennie | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks I will check this out
Bennie | | | | | Joined: May 2012 Posts: 3 Moderated | | Moderated Joined: May 2012 Posts: 3 | I need two rear shackles for my 1953 Truck. Where did you buy them? e-mail me at [email protected]
Roger W. Collier
