1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Trying to finish up install on new motor--Plug broke on the alternator and previous owner had a wiring harness. Blue wire shows #24, Black wire shows #42--hoping not to do a smoke test on it. Can anyone offer help on wiring to the alternator? Thanks, T.K. | | | | | Joined: Feb 2004 Posts: 29,763 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,763 | It would help to know which alternator you're running. If it's the 10 SI modsel with the internal voltage regulator, all you need to do is connect the big alternator output terminal with the threaded connector directly to a battery voltage source like the top terminal of the starter solenoid or the + terminal of the battery with a #10 or larger wire, and connect a jumper wire to the #2 terminal on the plug slot from the alternator output terminal. The other connection can be left loose unless you're running a "no charge" warning light on the dash. If you are running an ammeter inside the cab, the charging wire from the alternator needs to go to the ammeter terminal opposite the one that connects the ammeter to the battery cable terminal on thre starter. Jerry
| | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Thanks for all of the good info--appreciate the quick responses. Hope to fire the rebuilt 261 soon if my sore back holds out. T.K. | | |
