| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 41 | Brought home a new, (to me), '49 Chev 6400. Engine is not a 216 as first expected. I think it's a 235, but I need to learn all the variations of a 235. Valve cover has four hold down screws on side flange. Oil filler/breather in front top of cover. I cleaned off the machined ledge just behind the distributor and there are no stamped numbers. That leads me to believe it was a replacement motor never stamped. Truck is still 6V and oil pressure gauge only goes to 30 pounds which suggests to me it actually did have a 216 when new. No accessory gauges, so if this is a higher oil pressure 235, then they just let the gauge, "peg," or it's an early 235 with lower oil pressure, (did they have those?)
I did a quick search but I need to know more about 235's. Any tips or links appreciated. Thanks, Dennis Odessa/Ritzville, WA | | | | | Joined: Feb 2010 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 41 | Well, it looks like Spanky furnished some interesting information in another post a few lines down. Apparently my 6400 came with the, "Loadmaster," engine which was a 235. I didn't know they made a 235 in 1949. However, this now begs two more questions:
If true, does the 1949 235 have a real oil pump? Splash system? Insert bearings? And it must have produced only the 15-18 pounds oil pressure like the 216 if my dash gauge, (max of 30 pounds), is right.
Lastly, with no engine/vehicle number whatsoever stamped behind my distributor, if this means a replacement engine, could I still have a later engine and if so, how do I tell?
Dennis | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 235 engine was available from 1941 onwards. In trucks, the 235 engine was low-pressure (yes, with an oil pump) through 1953 and the earlier valve cover had 2 hold-down bolts/nuts. Here are the locations of various codes on the engine. | | | | | Joined: Jul 2010 Posts: 1 New Guy | | New Guy Joined: Jul 2010 Posts: 1 | Last year I purchased a 49 6400 grain truck that had a stock 235 ci. The motor is spent and I had a 216 that was rebuilt. Was the 216 ever pressurized? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 216 engine was always a low-pressure engine.
The 216 engine had a "pressurized" oil system; however, it was a low-pressure system that did not have pressurized internal lubrication to the rod bearings.
The truck 235 engines up through 1953 were also low-pressure engines.
| | | | | Joined: Feb 2010 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 41 | Thanks; that's a big help. So considering my engine has four screws on the flange holding it down and a low side plate, your links tell me it is a 1954 or later engine.
I did not realize that until 1954, the early 235's had the same valve cover as the 216, (twin center studs holding it on)
Dennis | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
