0 members (),
62
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | Sometimes when I start my truck the starter does not disengage. I will turn the key to off but it keeps spinning. Won't stop until I pull a wire off the battery. Would this be a Solenoid, starter or both problem?
Thanks, Mark | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Does this happen after the engine is running, or does it fail to start, and the starter keeps running when the key is released? Some starters put enough torque on the drive pinion while cranking that the solenoid spring cannot pull the gear out of engagement with the flywheel until the engine fires and unloads the drive gear. That's particularly true with a new engine that takes a lot of starter torque to turn the crankshaft. Tune the engine properly so it fires up and runs quickly, and that problem will probably disappear. If the starter is continuing to run after the engine starts, you might have a weak or broken solenoid plunger return spring, or a sticky solenoid plunger. Jerry
| | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | Thanks, pulled the starter had it bench tested. The solenoid was sticking. Mark | | |
