8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 15 New Guy | | New Guy Joined: Sep 2007 Posts: 15 | I'm trying to make some simple door panels out of 3/16" ABS plastic for my '52. The panels will be covered with fabric when done.
Here is my problem. When I secure the panel to the door, it rubs against the door lever machanism causing it to bind up. I can get the handle to work if I space the panel out, but then the stud for the handle is too short. The regulators are new reproductions. I really don't want to space the panels out and I don't want to add extensions onto the studs.
Before I cut, grind, weld and redesign the regulators, I thought I'd ask if anybody else has had this type of problem and how did you resolve it. Are the reproduction regulators my problem?
Thanks. | | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | would putting a couple spacers to slightly bow your door pannel around the linkage and give you a little clearance be too noticable once installed?
I'll be making full door panels soon and may have to go thru this also.
I'll be watching this post
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | There is suppose to be a spacer as seen is this pic from Mr. Denny Grahams web site Denny's door pic 3/16 might be too thick of panel material I glued material on that cheap cardboard the vendors sell and sprayed a sealer on the back. here's a pic pic 2 good luck | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | There is a regulators pad and plastic washer set that goes on ,the pad goes between the door and the panel and the plastic washer goes between the panel and the handle to keep it from screwing up your panel this would give you the spacing so you're reg. would work right I got mine from Clasic Parts of America and it's for both doors all 4 handles.
Part # 18-043
Cost 3.95
Pete
| | | | | Joined: Sep 2007 Posts: 15 New Guy | | New Guy Joined: Sep 2007 Posts: 15 | Thanks Guys for your help. I didn't know about that foam spacer piece stuck onto the door. I do have the fat washer and plastic washer so now I think I can make it work. I knew it had to be something real simple! | | |
