5 members (Stovebolt48, Wayne67vert, Peggy M, mo2cyl, 1 invisible), 168 guests, and 0 robots.
Topics128,083
Posts1,055,967
Members48,430
#667730 08/04/2010 11:49 PM
After being unsucessful locating new axles to solve a seal and bearing problem, I decided to replace the rear end with something newer. The original diff pinion was offset about 1 inch. Is there a reason for this? I am about to narrow a new rear end and have new axles made. The trans output shaft is centered in the frame. Do I center the new pinion or match the old one?
Doesn't make a difference one way or another of the diff is centered or offset. I'm not sure if you have the axle you are shortening yet. If not, you might look into an IMCA modified full floating 9 inch axle. They can be ordered in any width, lug pattern, and have many different options for disc brakes and gears. I put one of these in my 1959 gmc 1/2 ton after ripping the perches off the eaton ho33 axle that was in there. Anyway, there are plenty of axles that will work without having to cut em down, so do a search and you might save some money.
