7 members (Wayne67vert, Otto Skorzeny, Chris's 46 / 515, KEVINSKI, JoergK., WICruiser, Ole49GMC), 97 guests, and 6 robots.
Topics128,172
Posts1,057,109
Members48,463
Back in the mid 60s my Father had this truck,with a Pontiac V8 from the factory.what was the c.i.,and were they left over engines that Pontiac no longer used?
Check the " old gmc trucks" site-- there is a lot of info available.
Good luck.
Good luck.
Yes, and it is more accurate than that wiki article. It has some bad info in it.
It is interesting to note these early gmc/pontiac motors were reverse cooled motors. That is to say the water was directed to the heads first, and then down to the engine block. It is also interesting to note that these motors do not share the later Buick Oldsmobile Pontiac Cadillac bellhousing bolt pattern.
