0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I have a '49 with a 283 with HEI. All of a sudden now it won't start when it's hot. When it's cold, it fires right up, but when it's hot, it won't fire, just cranks and cranks. I've got a new battery and replaced the coil today, but it's still the same. Just wondering about the starter itself. Anyone have any suggestions? Thanks for the help.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | If it cranks and cranks, I don't think the starter is the problem. Think about it, if it won't start when its hot? Check to see if your getting any fuel, check to see if you've got spark! What the condition of the HEI? Probably something simple, keep trying. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Check the module in the dist. take it to any auto parts place they usually check for free,but when putting it back be sure to put the dielectric grease under it or it will not last long.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 37 | How about the plug wires; are they old? Or, the plugs themselves? Another thought is vapor lock. Is the gas cap vented? | | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | +1 on ign module. been there done that. Very true about the grease. don't try to get by with what's already on there even if your putting the old one back in. parts store prob has single use size packets you can get for less than a buck.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
