3 members (Peggy M, RLB, TUTS 59),
105
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I thought I knew when I ordered these.......but where do these go on the shifter tube? I don't follow the explanation they give....anyone? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Those are the grommets for the shift control rods where they attach to the column shift arms per their explanation. Seems clear enough to me. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | Dave...you are a lot more familiar with the nomenclature of parts than I. Are the shift control rods the long rods that change the gears and are the column shift arms the two small levers where the rods attach? If so, I have two rubber bushings for that joints....do the grommets go in as well? | | |
