3 members (Rusty Heaps, Southerntruck, 1 invisible), 167 guests, and 2 robots.
Topics128,087
Posts1,055,985
Members48,430
#667195 08/02/2010 10:19 PM
I thought I knew when I ordered these.......but where do these go on the shifter tube? I don't follow the explanation they give....anyone?
Those are the grommets for the shift control rods where they attach to the column shift arms per their explanation. Seems clear enough to me.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dave...you are a lot more familiar with the nomenclature of parts than I. Are the shift control rods the long rods that change the gears and are the column shift arms the two small levers where the rods attach? If so, I have two rubber bushings for that joints....do the grommets go in as well?
