6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#665611 07/27/2010 9:42 PM
1 Offline
Hey all, I bought the kit trying to install the calipers and they just won't slide on....Any Idees?
3B Offline
Hy 12181955,could you PLEASE try and give us some more information, what year and size of truck, whose kit did you buy, what size of parts. Did the kit come with directions, did you follow them to the letter and things still won't fit together???
1 Offline
1949-55 54 CHEVY GMC TRUCK DISC CONVERSION KIT BRAKES from Classic Performance. My truck ia 1952GMC I/2 I have the rotors on and am currently trying to get the calipers on but no soap
Hi
I installed the kit from P.O.L. on my 1950 1/2 ton
Here is a pic.
pic 1 passenger
pic 2 passenger
I had no problem installing the calipers but I do remember the instructions stating that I may have to grind the backing plate for clearance, Mine went on with no problem.
pic 3 drivers side
Where is it binding? Gonna get simple here, no offense intended, but are the piston and pad fully pushed back? Or is the caliper not fitting into the backing-plate mount? (see above about grinding.)
They will go on, just might need some help.
Good luck.
Look at Dads50 pictures. The gold colored bracket can easily be reversed especially if you try to follow the obscure "instructions" that come with the POS kit from CPP.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
1 Offline
Yes, I had the plate on backward. These kits ain't idiotproof. Thanks all!
