| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66654 09/30/2006 5:10 PM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | I have just changed the stock non-power steering, non power brake spindles on my 65 with some from a 75 c-10 that had power steering and non-power dics brakes . I've got the left side all up under it and was going to tighten up the ball joint nuts when I seen that I only have about a 1/2' of clearance between the stop on the spindle and the stop an the lower a-frame . I don't think this truck is going to trun to the left . Thr a-frames are from the 65 and I used the moog ball joints that everyone said I needed. I have no tie-rods nor anyother parts hooked up as of now, But something don't look right. Has my head jumped time or have I forgotten some thing ? Do I need to trim the spindle stop ? :confused: :confused:
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
#66655 09/30/2006 6:18 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The old memory is foggy, but it seems I ground the spindle stop on one side or the other on mine(64 w/later discs-been 4-5 years) to get it to turn equal on both sides,,you got a picture of that 58 Lincoln??Brian | | |
#66656 10/01/2006 2:31 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, My head stays foggy, 40+ years of mechanic work too many cans of carb and brake cleaner have been sprayed around my head. I think when I put the rest of the front-end on I can get a better grip on things. I'll have more questions in a day or so. I've got many pic of the 58 MKIII coupe but am stupid as how to post them. Even have some of the 58 lincoln and the 65 truck together. I can E-mail them to someone else to post . Thanks, George
#66657 10/10/2006 1:48 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | O.K. Now for the other questions. The Ilder arm off of the 75 is bigger and more like I'd want to use. It bolt right to the center link from the 75. I used all the tie rod ends and p/s box. When I tried to mount the arm to the frame of the 65 the angles are WAY off. Tried to mount the 65 Ilder arm and the angles look about right using the oringal holes. The problem is the 65 and 75 arms have differant size tapers to the studs on them. If I use the 75 arm and have to drill new holes,how will I know where just a quess and what is right IS RIGHT. Is there a adapter to mate the 65 Ilder arm to the 75 center link? The 75 arm is about 3/4 at the top and tapers down to 11/16 (all these # where taken after a 13 hr. day ,in the middle of a six pack , Soo... ) The 65 is 5/8 at the top and 9/16 at the bottom. Any Ideas ? BTW , right now no motor and up on jack stands. Thanks, George Hood
#66658 10/10/2006 3:02 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You have to drill new mounting holes in the frame for the later idler arm. If you can't measure a newer truck, I have a sheet somewhere where someone else measured one. Brian | | |
#66659 10/10/2006 6:02 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Brian, Please post the measurements if you can find them because I am about to undertake the same upgrade. I've got all of the parts gathered up, rebuilt, cleaned and painted from a '79 and I was sitting in the garage the other day puzzling out the exact same thing as George. I can still get to the donor truck to measure if I have to, but what to measure and how? Given the number of people that are doing this upgrade it seems like a very good topic for a tech tip. By the way...I found the PS bracket (one piece in CO and the other piece in NJ).
Thanks. Morris | | |
#66660 10/10/2006 6:36 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I will look for it-I just saw it the other day, but that don't mean much. Between the 1 y/o & the 6 y/o nothing is ever where I put it. Brian | | |
#66661 10/11/2006 1:51 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, I too am like Morris, I can't figure out where to measure to make it all be in the right place for the final wheel alingment, but not having any weight nor the springs compressed is going to make a big difference when it is finally set down on the wheels. I too have the doner truck near by and will make a template ,but another opion and specs would sure be a help. Thanks ,George Hood Morris, Nice looking 63. Make sure your son keeps is eyes on the road and not the young girls. About 12 yrs ago when my son frist got his D.L. it cost me the new chrome bumper and grill on this very same 65. Good Luck,George
#66662 10/11/2006 2:07 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, Did the e-mail pics go through to you ? George
#66663 10/11/2006 2:15 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | OK, I got it scanned but it is small, I am trying to figger out how to get it darker & larger-maybe if you save it to your PC you can make it bigger. My wife & I are still working on it. idler measurements I could also fax or snail mail a copy if needed,, Brian | | |
#66664 10/11/2006 2:18 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | George, 3 pics came thru but Hotmail would not let me open the others-sharp looking Lincoln! Brian | | |
#66665 10/11/2006 2:40 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Brian, Thanks for the info...
George, He already cost me a new front bumper on the '96 F-350...the truck died and he had an equally knowledgable friend tow him home...by wrapping a tow strap around the middle of the bumper! | | |
#66666 10/11/2006 6:27 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Were you able to enlarge the scanned pic so you could see it? Brian | | |
#66667 10/11/2006 7:10 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I can see the diagram, but I couldn't read any of the numbers. If we can get the numbers where I can read them I'll do an electronic version of the drawing in Visio and post it here. | | |
#66668 10/11/2006 9:29 PM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Morris that might be what we need. I to can not read any of the numbers. I work as a road mechanic for a power company ,being out there with no shop to help me I sometimes get the print of a bucket truck or digger fax to the house. Most of the time they are useless. George
#66669 10/11/2006 10:54 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | How about we do this...Brian, I'll PM you my address and phone number. Call me. I have a fax machine at home, but it operates on the same number as my regular telephone line so we'll have to coordinate a little bit when you are ready to send the fax. If I can't read the fax you can send me a snail mail copy. If I can read the fax I'll put together a visio drawing of the information, publish it as a PDF document and email it back to you guys. If we want to take it one step further we could write this up since George and I are both about to undertake the same work and maybe Peg would put it on the site for other folks as well. | | |
#66670 10/12/2006 3:15 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, Morris, My Fax # is 1-910-564-2682 . Brian, I only sent 3 pics,so I quess ya got them all. Thanks to all for the help
#66671 10/12/2006 5:25 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | George...PM me your email address so that I can send you a copy. | | |
#66672 10/12/2006 5:31 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Never mind...you should have it in your in box | | |
