| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I pulled my carb apart cleaned it best I could? Used a rebuild kit, but I'm not seeing any gas at the jets? It's back on my work bench and I'll pull it back apart. I think something must be clogged. Any help would be much appreciated. Thanks Brett | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Kinda hard to rebuild a carb, especially via the internet. Are you sure its the carb? What about the fuel pump, fuel line, filters, and fuel tank? Have you cleaned everything up? Was it running before? The more information you can provide will help those that are knowledgeable in carburetors. | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | yes I it ran before. unitl I pumped all the crud from the tank. I've cleaned the tank out and get fresh gas through the filter. Pretty sure it's the carb. thanks Brett | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | looks like my float was stuck, no letting gas in. Now it seems like it is stuck open and just floods the engine out. any ideas would be great. I'm thinking of going to a new manifold and carb. Thanks Brett | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | seems like it'd be a lot cheaper to cure the problem, sounds like you didn't get all the junk out and some is keeping the needle from seating properly
Bill | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thanks for all the advice.Pulled it apart 2 more times, the last one I noticed the float looked crooked. Yup I must have bent it during first rebuild. A little cranking and Betsy fired right up. Stovebolters are the Best! Thank You Brett. | | |
