Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#665749 07/28/2010 4:39 AM
I have a 56 with 316 v/8 and was GMC orange/red Jim Carter has paint with spray adapter rattle can I think. I assume I need a primer to get a decent job?
will rattle can primer work? Does the JC orange /red apply easily and stand up to heat? Your help will be appreciated. tom smile
Can't say I've ever seen a engine primer. I've never used a primer, nor have I ever been able to detect one ever being used when taking the paint off a motor.
Now that don't mean there ain't one out there, but I don't see the need for one and I've painted a bunch of motors.
The high points are what is hard to get coverage on so when you spray it don't try to get coverage all at once. Give it the first coat, wait till it almost dries and hit it again. A third might be necessary but stay away from build up, thickness, as heat has a habit of cracking the paint if it's thick.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
I have gone both ways...with and without engine primer. Over time I have noticed the engines with primer paint holds color much better. I do not suggest using one brand of primer and a differnt brand of top coat. They should be from the same mfg.
Use a good self etching primer. Dupont variprime is good, it has an acid additive that makes it self etch to metal. I used it on the engine in my Chevelle.
I put on one good coat , then went over it wet on wet with seymour's
Engine enamel from a spray can. I did this 10 years ago & it still looks good.
