1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | My 216's got a freeze plug in the hole where the crankcase pressure release valve is supposed to be...right by the fuel pump. For some reason, the last owner didn't think this part was necessary..?
How should I remove this plug? Im thinking drill a hole in it, stick a crooked screwdriver-thingy in there, and see if I can work it loose.
Any other thoughts?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | not sure about that location, but for regular freeze plugs i sometimes drill a hole and use a slide hammer. if that doesn't work i drive one side in with a chisel and grab the other with a large pair of pliars. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Green 98, sounds like you may be talking about the hole for the draft tube that someone may have stuck a freeze plug into. I'd check this out and see what's up. Sounds like a modification from original, have seen racers do this to eliminate the down tube. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | IIRC one of the PVC installation kits required removal of the road draft tube, and blocking the hole with a freeze plug.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Not sure what you mean by the 'down or draft' tube, but I know its called the crankcase breather / pressure ...etc. On the 216, its located by the fuel pump on the front of the motor. For some reason, ours has been modified and a freeze plug put into the hole. Check out this pic. Its the long thingy that hangs down below the oil pan and mounts in between the fuel pump and distributor. [img] http://www.adchevy.com/images/public/chevy216large.jpg[/img]
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That is the road draft tube you are referring to. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yep, don't know about Mississippi but every where else it's the road draft tube. It aids in ventilating the crankcase.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I wouldn't drill that with the chance some metal shavings might get in the crankcase, knock a hole in it with a sharp chisel and use the honkin big screw driver to lever it out ... and yes, it's called the road draft tube, no "valve" involved and no pressure possible in the pan if it's working correctly someone might have removed it cuz they didn't like the truck spotting up their driveway, if there's not some air inlet and a non-stock hose into the air cleaner from somewhere to ventilate the interior, that'll be the reason you need to rebuild the engine  Bill | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Good point, I'll knock a hole in it and not use a drill.
Could that be the reason that we've never been able to get our truck running correctly? Our motor gets full compression on all cylinders, doesnt smoke, has new cylinder head and all components, and is timed out correctly, and we've never been able to get the darn thing to run right.
Oh and for the record, it's Mis'sippi down here! (spoken like you have a mouth full of hickory nuts)
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I used to date a gal who was miss-hippy.
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Well there are a few hippies down here...quite a few from the delta
