| | | Forums66 Topics128,084 Posts1,056,334 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66609 09/28/2006 12:24 PM | Joined: Sep 2006 Posts: 2 New Guy | | New Guy Joined: Sep 2006 Posts: 2 | The u-joint in my original 3 spd failed and the tailshaft for my tranny snapped off. I have acquired a 3 spd overdrive from a 1955 that I'd like to install. I have a new open rear end. My original engine had been replaced with a later model 250 with side mounts replacing what I assume were front and rear engine mounts. The new tranny does not have any obvious mounting flange, but I am guessing it needs more support. Do I need to find a bell housing that will provide rear engine support and leave the tranny hanging or do I need a rear trans mount? | | |
#66610 09/30/2006 2:02 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | My sm420 heavy duty 4 speed is bolted directly to the bell housing which is sitting on a brace. There is no mount on the back of the tranny. On my 72 truck there is a brace on the 700r4 automatic. It doesn't need anything else. That's all in there pretty solid. | | |
