1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | I disassembled and cleaned up my speedometer over the winter, but it has died a permanent death. Odometer still works fine so I know its not the cable. I have ordered a new speedo assembly, but it comes with the odometer set to all zeros. Any pointers of how to set the numbers to the current odometer reading when I install it? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Should be able to pull it out and rotate the little metal tabs between each digit to advance them (without spinning the whole thing for miles and miles and miles)
It's been a while sense I plaid with mine, but I had no problems presetting it before installing the actual odometer number/counter assembly.
Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once hooked an electric drill to the trans end of the cable and ran an odometer a few thousand miles to get what I wanted. If I were doing it again I'd take it apart and reassemble with the numbers I needed.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
