4 members (Shaffer's1950, cmayna, 2 invisible),
122
Mod | | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Just broke the driver's side rear axle. Anyone got one? 29&1/2" ( maybe 30" ) 30 splines outside bearing. EB's 63 [email protected] | | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | This maybe for RJ....do you have one
It is 29 & 9/16" long 30 splines outside bearing no C clip application bearing # N.B 5d14003 Hotchkiss rear end ( I think ) | | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Well an outfit in Portland O. Dutchman will mill new axles ....so that's the way I decided to go. Better alloy and no metal fatigue.
EB | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | i am sure i have one. but it looks like you found one. | | |
