8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#665775 07/28/2010 6:43 AM
Ihave a 1975 nova 250 6 cyl,which has a intregal head.Does someone know what other head will fit this block so I can get a intake for duel carbs and maybe a header?Tom
tmcculley #665803 07/28/2010 11:50 AM
Any head from a 194 to a 292 will work. The 194 will raise the compression to around 9.0 to 1. Inliners.org has a good listing in the tech section if you can't find it above.
Just a side note, once you find one, use caution when torquing the left front head bolt, only go to 85 ft pounds, not 95. Its also a good idea to have the water pump bolted in just for more support. The water pump opening creates a weak point in the block and you can easily break it.
Joe
Joe H #666514 07/30/2010 11:29 PM
Thank you for the help Tom
