0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | I am replacing the rear leaf spring shackles on my '50 Chevy pickup. The shackles have two threaded pins with tapered ends. One pin threads through the leaf spring eyelet and a second pin threads through a hanger riveted to the frame. The threads on the hanger are now eggshape and the pin has lots of play. I can find replacement shackle kits but I cannot find anyone who makes the hanger. Does anyone have any leads on where I can get one? What other options do I have in this case? | | | | | Joined: Jul 2010 Posts: 12 New Guy | | New Guy Joined: Jul 2010 Posts: 12 | you could weld up the hole and re drill it | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Had not thought about that as an option. Thanks for the suggestion, 73scoutcrawler. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Old_yeller, that is actually a threaded bushing inside that "hanger", it can be driven out and replaced, hope that helps. | | | | | Joined: Jul 2006 Posts: 2 New Guy | | New Guy Joined: Jul 2006 Posts: 2 | get your hands on some plastic called UHMW or nylatron. Have it machined the same size round as your hanger was original. Drill for your pin size and install. It is strong enough to bridge the egg shape and will wear better than iron. And it is self lubricating. My 54 was really bad, it has been 10 years and is still working great. I have used UHMW in 20000 lbs forklift king pins for years for bushings. It is amazing. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Thanks, Dmac. I have never heard of nylatron but will certainly see if I can find it locally. That looks like an easier fix and one that should last as well. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Thanks, 3B. I wondered if that was the case when I cleaned up the hanger. This website has lowered my anxiety greatly. Thanks again. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is a threaded bushing inside the hanger as stated and it needs to be replaced with another one. They should be available as part of a set. | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Is there a good way to remove the bushing in the hanger without having to remove the hanger from the frame and pressing the bushing out? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Is there a good way to remove the bushing in the hanger without having to remove the hanger from the frame and pressing the bushing out? Yup. It's in the tech tips: http://www.stovebolt.com/techtips/bushingpuller.htm
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Is there a good way to remove the bushing in the hanger without having to remove the hanger from the frame and pressing the bushing out? On my '58, I used one of the old bushings with a pin in it and ground down a bit so it wouldn't get stuck (used as a "punch"), some heat, and a BFH. It still didn't come out easy, but it did finally come loose. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I haven't had to do this one myself but I have read where with some bushings, cutting a slit with a hack saw blade helps things along. I don't know if you have that kind of access. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I successfully used that Tech-Tip but made few changes as described here. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Excellent Tim, thanks for sharing that. Any chance of getting this added to the existing tech tip?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jul 2010 Posts: 19 New Guy | | New Guy Joined: Jul 2010 Posts: 19 | Thanks, Curt for the tip. I can see it working well. I was able to remove one of my bushings by heating the hanger and then pounding out the bushing. I screwed in the old threaded pin, heated the hanger and used a 3lb sledge to pound on the pin. I had to get the hanger pretty hot for the bushing to give, but eventually worked it out. | | |
