3 members (klhansen, Otto Skorzeny, Wally / Montana), 58 guests, and 2 robots.
Topics128,052
Posts1,055,726
#665094 07/25/2010 9:19 PM
there's a small spring... maybe 3 inches in length that was on the backside of the carburetor that broke, that holds tension on the acceleration linkage. I'm not sure where one end hooks to. One end goes in an "arm" coming out of the carburetor... but the other end I'm not sure where it goes. In the Jim Carter catalog they have a vertical spring and a spring holder tab bolted onto the oil pan. Mine doesn't have that tab, so I'm not sure what it hooks to.
In my 52 AD the spring goes to the hook on the bell housing so the accelerator goes back to its original position after you release the pedal.
Spring
Ganesh
Most of the vertical accelerator rods have a tab welded to them right up where the rod passes the exhaust manifold. The spring attaches there to pull the acceerator back to an idle position. The other end does attach below to a tab in one of the oil pan screws. I've seen factory tabs and various other products. I use a Mr. Gasket right angle chrome piece attached to the oil pan screw and it turns up for the spring to hook into a factory hole in it.
