| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 19 New Guy | | New Guy Joined: Mar 2007 Posts: 19 | there's a small spring... maybe 3 inches in length that was on the backside of the carburetor that broke, that holds tension on the acceleration linkage. I'm not sure where one end hooks to. One end goes in an "arm" coming out of the carburetor... but the other end I'm not sure where it goes. In the Jim Carter catalog they have a vertical spring and a spring holder tab bolted onto the oil pan. Mine doesn't have that tab, so I'm not sure what it hooks to. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | In my 52 AD the spring goes to the hook on the bell housing so the accelerator goes back to its original position after you release the pedal. Spring Ganesh
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Most of the vertical accelerator rods have a tab welded to them right up where the rod passes the exhaust manifold. The spring attaches there to pull the acceerator back to an idle position. The other end does attach below to a tab in one of the oil pan screws. I've seen factory tabs and various other products. I use a Mr. Gasket right angle chrome piece attached to the oil pan screw and it turns up for the spring to hook into a factory hole in it.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
