0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | Ran battery down, charged (took it well), started '52 1/2 ton, stalled it, went to start again adn battery almost flat.
Cables fairly new, spins great with jumpers. Is the battery toast?
Wayne | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | get it load tested, may have a bad cell
Bill | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | If you have a meter, measure the voltage when removed from the circuit and when the truck is running and post.
Dave
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Depending on how long it was between your start and your stall, your generator/voltage regulator might not be charging your battery either. That's my case; truck will only last about an hour.
Dave
| | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | Stalled it 60 seconds after starting, didn't get out of driveway. Probably a good thing. | | |
