0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#663187 07/17/2010 8:16 PM
Ran battery down, charged (took it well), started '52 1/2 ton, stalled it, went to start again adn battery almost flat.
Cables fairly new, spins great with jumpers. Is the battery toast?
Wayne
get it load tested, may have a bad cell
If you have a meter, measure the voltage when removed from the circuit and when the truck is running and post.
Dave
Depending on how long it was between your start and your stall, your generator/voltage regulator might not be charging your battery either. That's my case; truck will only last about an hour.
Dave
GMCdp #664656 07/23/2010 11:19 PM
Stalled it 60 seconds after starting, didn't get out of driveway. Probably a good thing.
