| | | Forums66 Topics128,079 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Hey guys. I found a set of 15 inch 8 lug aluminum wheels. I've never seen a set before but there 8 lug. Is 15 inch too ssmall for my drum brakes? I thought someone might know before I pulled the tires off. 61 3/4ton 2wd
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Without knowing where they came from, about the only way you can find out if they fit is to try them. GM, Ford and Dodge all use 8 hole. It would surprise me if they don't fit over your drums, but the back set may be wrong.
