1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Hopefully someone can help me, as I have been suffering with this problem for a while. I am short a car so my 1946 Chevy Stylemaster Sedan is my new daily driver for the time being. I drive 40 miles a day. The car has a 216, and three on the tree. I have been experiencing a very bad vibration in the rear between 60-65 MPH. Today I had a guy pull me over to tell me it looked like my wheels were going to fall off. When I got home I had my father come take the car out and I rode behind him. Basically, at any speed, when you hit a bump the rear axle jounce is horrible. You can see the axle literally vibrating up and down and its continuous. At higher speeds it takes a long time for this to stop happening. I am thinking the shocks are shot, But i have actually never seen anything this bad. What do you think?
DG
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | A combo,bad shocks,tire's out of balance, or just old tire's ready to delaminate. In the mean time slow it down. No since in causeing more damage,then necsesary. I had a set of old radials that looked good,and started woobling and causing problem's like your describing.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | The tires are horrible... rock hard straight line bias plys... I would really like radials but I can't find anything to fit my tiny rim.
DG
| | | | | Joined: Apr 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 34 | Assuming you're running the 16 inch 6-bolt rims, these would be 4.5 inches wide. A 215R75-16 Radial Tire will fit no problem, I've been running 215R85-16's on my Panel with stock rims for 20 years with no problems other than inner tubes wearing out. | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | yup, that's the size, however mine are tubeless as far as I know.
DG
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When you say the rims measure 4.5 inches is that outside to outside or to the inside where the tire bead sits? I had 650-16 and wanted 215-85R16 but two dealers would not install as they claim my rims were too narrow. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Over 50 k miles daily driver only vehicle, no flats no loss of air pressure, no tubes, stock rims, got my information from the former president of Inliners 12 years ago.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
