8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible), 40 guests, and 1 robot.
Topics128,090
Posts1,056,020
Members48,430
#66395 09/24/2006 10:51 PM
Junior Member
Junior Member
I'm buliding a 235 to go back in my 51 3100. What I have learned the hard way is that all 235's are not the same. This block has a Chevy parts number of 3764476 which I understand makes it a 56-62 engine. The oil pump screen, tube and pipe from pump to block from my 54 "parts" engine do not work on the newer project. Any thoughts on how I can retro-fit or where I can find replacement parts that will fit? Can I still use the 54 pan?
#66396 09/25/2006 4:38 AM
I
I Offline
the 54 235 and 261 are differnt than the newer ones. I beleive the pan would fit, but the internal stuff won't. I had this trouble with my 261. To solve it the dealer let me order everyone the the 5 differnt pumps listed. i just picked out the one that matched mine and sent the rest back. The fittings from the pump to the block and the oil screen assembly are going to have to come from an engie of the same yr and type.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#66397 09/25/2006 5:00 AM
Welcome to the Stovebolt community.
Hundreds of un-enlightened people have cast these reliable old 235 engines aside to put boring crate 350s in their truck. A pat on the back to you for not doing so.
That said, it should be easy enough to find someone with an old 235-261 laying around you could raid for parts.
I'm sure you already know the pump itself should be a new one for your rebuilt engine.
Good luck with your project. If you run into any problems, use the search feature of this board. Chances are someone has already solved it. Keep us posted on the project
#66398 09/25/2006 10:58 PM
Junior Member
Junior Member
Thanks for the suggestions. I'll hit the junk yards this week-end and see what I can find. If I can't find one there, I'll use the pick-a-pump method.
#66399 09/25/2006 11:56 PM
phillip1997
I had good luck at NAPA with my 235 oil pump.
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#66400 09/26/2006 3:06 AM
Junior Member
Junior Member
Thanks acwhite. That is where I got the pump. I found a screen this afternoon, so I am down to looking for the pipe from the pump to the block. May try a junkard in Dahlonega this weekend.
