| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Looking for help on the '48 clamshell Burb (guide r-13) taillamp. I've had the truck rewired with Classic Harness but didn't have the tail lamp done at that time. The tail light works but cannot figure out the stop lamp. I have four wires to the rear (two purple, white and a reddish if I remember correctly)They are not numbered in the back and I am currently unable to crawl under and look.I know a lot of you guys have used this harness, any suggestions? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I will not be near my trucks and/or the Classic Parts (Chevy Duty) instructions for a few weeks. As I recall, the purple wires are for turn signals (non-standard wiring). It is possible to wire it for the single tail lamp - maybe someone near their one-tail/stop-lamp Classic Parts harness installation will post a reply.
Are the purple wires exactly the same (or does one have a ridge or stripe on it)?
Did you try calling Classic Parts Technical Support?
| | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | If I recall they look the same but I have black electrical tape on the one because it's the only hot wire. I think I need to have the hot wire and the white wire ( which I think in the front is connected to the stop lamp switch) wired together at the rear and the other grounded and should work, right? Haven't been able to try that combo yet. Maybe my guy has a wire hooked up wrong in front regarding the purple wires, it seems they should be for the signals though. I'll have to check today | | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | dark purple- tail lamps pink- left turn & brakes on dual taillight application light purple-right turn & brakes on dual taillight application white- brakes on single taillight application if on dual taillight application you can use white for backup lamps by putting switch at dash and running jumper to front end of wire.
Many times taillight problems can be eliminated by running ground to each lamp base. | | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Thanks a lot for that info!! | | |
