5 members (1955 1 Series, 78buckshot, Gdads51, Gray_Ghost, 1 invisible), 106 guests, and 3 robots.
Topics128,180
Posts1,057,067
Members48,460
Moderator
Moderator
2 Offline
Asking for help to tell me what is parked in my barn.
It’s a 1967 GMC ladder truck with a 637ci GMC V-8 and the granny gear five speed.31,000 GVW.
VIN # TE 9700AH D2925H
The Fire truck end is built by
American Fire Apparatus out of Battle Creek, Mi.
S/N 2951-8-67
Does any one know where to get more info?
Any thoughts and advice would be appreciated.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
The truck is a 9000 series truck which is the largest conventional cab GMC built. The engine put out something like 275 HP 2800 RPM and 600 ft. lbs. torque at 1600. By 1967, most 9000 series trucks were speced with a Diesel engine. However fire departments favored gasoline engines because they started easier in cold weather and didn't require the warm up period of a Diesel. They were a strong reliable engine, but not many of them were produced because of the fuel economy. Fire departments, of course, didn't care about fuel economy. They are an interesting engine and a very rare one. Not much has been written about them because they were built such a short time, and not many of them were built.
Moderator
Moderator
2 Offline
Thanks Crenwelge
I have heard it was a rare setup with the engine and tilt cab.
Less than 15,000 miles on it and the body has zero rust with real good paint.
Don
"The Flag Pole"
1953 1-ton pickup
Don,
TE in you serial number decodes to:
T = Tilt Cab, 72" Steel
E = V8 Gass Engine
That's all I can help with...got pictures?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I don't have GMC books that go past the early 60's but I do have books on the engine. I didn't realize it was a tilt cab. However the 9000 series is the largest series GMC built. We had this same truck with a 478 V6 in it for a while, but it too was a gas guzzler. The same cab was offered with a 6V71 Diesel. The 637 would actually outrun the Diesel, but at the expense of using a lot of gas. The steel tilt cabs were designed for maneuverability in cities. They never found much favor on longer hauls. However, fire for fire equipment they worked well. I have no figures, but I would guess that fire equipment was probably the largest user of the 637. And fire equipment is quite often in mint condition because it was always garaged and well maintained.
crenwelge, Was the 478 factory original in that truck? If I was, was the truck actually an 8500 Series?
Also, I agree that the Fire Trucks were the biggest user of the V-8 637. I had one of the only ones that I know of that wasn't a Fire Truck. As many know, it was a '71 9500 Conv Cab Tandem, with a 20 Ft Flat Bed Dump. It is also the only 637 that I know of that had a 10-Speed Road Ranger behind it. I didn't hate the engine, but I always wished the company I worked for ordered it with a 6-71 or at least a 6V-53 Detroit.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
The 478 was original to the truck, but I don't remember the series, but I think it had to be an 8500 series. I bought it in the 80's to jockey trailers around town. I think it was probably the same cab as they used in the 9000 series. I even went so far as to put a Bartlett hydraulic 5th wheel on it. We quit using it when all of our road tractors had air ride and suspension dump and insurance got too high on something that never got more than 5 miles from the yard. I sold it along with a load of salvage around 5 years ago. I wish now I had cut it and kept the components. I am now looking for a steering axle and a heavy 2 speed with Dayton wheels on straight air to put under my 1957 600 GMC. I don't care about the 478, but I am sure someone on a forum like this would have been happy to get it. One of the local feed stores had a 637 in a conventional with drag axle. By then I had all Cummins with twin screws and didn't pay much attention to it. The family sold the feed store recently and there were a bunch of old trucks around back. I think they were scrapped because they even removed the grain tanks in an attempt to sell the building. I'm not so sure you would have wanted to trade the 637 for a 6v53. We have one in our yard mule and its fine, but I'm not so sure its got the power you would have wanted.
I had a 6V-53 in a '67 7500. You may have a point as I maybe just favor a diesel in general, but both engines required a lot of shifting, especially when fully loaded and up and down hills. I didn't mid tho as I always liked shifting. I guess a 6-71 would have been the answer for sure.
Do you remember what the feed store 637 truck had for a trans?
GMC 9500 Fan
Detroit Diesel Fan
As far as shifting goes, the fun goes away after a while. I still own trucks and occasionally have to make a trip myself. Our Cummins engines set at 1650 ft lbs torque sure nice compared to the gas burners and even the earlier Diesels worked a person to death. And from an economic stand point, every time you shift, you put a jerk on the entire drive line. Its unbelievable how long our components last now compared to just 35 years ago.
It was Farmers Grain in Fredericksburg, TX 78624. One of the family members is still around here.. David Weinheimer. He has a publicly listed phone number 830 997 3979. I think Harry Moldenhauer was the driver that drove it. I think he is in the nursing home.
Well, I've been shifting gears for 41 years straight now and never lost any love for it, but I'm sure I'm in the minority catagory, lol.
Don, didn't want to Hi-jack your thread. If you have anymore questions on the 637, just ask away. By the way, aren't you the one that just bought the Aerial Truck? Do you have 2 Fire Trucks now?
GMC 9500 Fan
Detroit Diesel Fan
Moderator
Moderator
2 Offline
No Bill
You did not hijack this thread.
The more we talk and listen, the more we learn.
I only have one fire truck and two 2-Ton grains.
The gas peddle linkage on the cab over shot craps yesterday.
Does anyone know if a cable throtle linkage would work.
Fire trucks are chick magnets.
Even if the truck is just sitting in the yard, with my ladder up.
Don
"The Flag Pole"
1953 1-ton pickup
Did the '68 actually turn out to be a '67?
Not sure about your Throttle Linkage. Can you try to repair the original one? A Cable will probably work with a little tinkering.
GMC 9500 Fan
Detroit Diesel Fan
Moderator
Moderator
2 Offline
Yes the 68 did turn out to be a 67 ladder truck.
The gas peddel just fell off and was laying on the floorboard.
Then the slide linkage for the tilt cab broke free from the gas peddle when I tilted it up to see what was wrong.
The linkage had been cobbed up before I got the truck.
I can repair the old style linkage, but a cable system may be a better design and last longer.
I can still move it in and out of the barn by kicking up the aux throttle.
This thing does run good and as far as the fuel milage goes, it's cheaper than running a boat and draws way more Chicks.
Don
"The Flag Pole"
1953 1-ton pickup
Moderator
Moderator
2 Offline
Just to set the record straight, I am happily married and my wife knows it is a babe magnet.
It's storming right now and I guess I need to learn how to link some pictures.
Keep the comments comming.
Don
"The Flag Pole"
1953 1-ton pickup
Moderator
Moderator
2 Offline
Try this link for pictures.
If it does not work, I'll try again some other time.
The storm has passed and its time to get out and do something.
ZooKeeper, the storm is headed your way.
http://s893.photobucket.com/albums/ac132/2-Ton/
Don
"The Flag Pole"
1953 1-ton pickup
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
It flew threw about 30-45 minutes ago, what a hellva way to get woke up with the sound of BOOMMMMMM!!!!!!!!!!.
Thats a good looking piece of machinery. I think I saw it advertised somewhere, but I'm into the earlier GMCs. Does it have a hydraulic clutch? Between the throttle linkage and the hydraulic clutch on the tilt cab I had, it was always something. However we were using and abusing it daily to move trailers around. It was by no means a show piece like yours.
Moderator
Moderator
2 Offline
Cren
I guess the pictures worked
Yes , it has a hydrolic clutch and there is a lock out by the pump controls so it cannot be put in gear when pumping or extending the ladder.
I still have a lot to learn about this machine.
John and Peg will be after me to post pictures now since I just learned how to.
Don
"The Flag Pole"
1953 1-ton pickup
I just noticed it has a compressor. The older fire trucks always had hydraulic brakes because the insurance companies thought it would take too long to build up air pressure. I guess by 67 they had gotten over that silly notion. With air brakes, you can always get more air, with hydraulic brakes, once the fluid is gone, its gone. Be sure to check the fluid in your hydraulic clutch regularly. Its easy to add a little, but if you let it go dry, its a real pain.
Just a little history on the 637. When it was first introduced, the engine wouldn't last until it got to the dealer. There was a stop production order and it took 4-6 months to find the cause. Seems that someone in the setup of the machinery for production of the engine block changed the size of one hole in the oil pump area and caused a 100% failure of the engines. I remember sold trucks that we couldn't repair for months and, believe me, the customers weren't easy to deal with both at the time and the next time they wanted to buy a new truck.
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
any pictures of this truck?
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
Do you mean the '71 9500?
GMC 9500 Fan
Detroit Diesel Fan
Moderator
Moderator
2 Offline
Check out these pictures of the 67 9500 GMC
2-Ton
"The Flag Pole"
1953 1-ton pickup
