6 members (Lostbuthaulinass, Peggy M, Joe H, 50Chevy3100, Shardean, 1 invisible), 86 guests, and 2 robots.
Topics128,057
Posts1,055,815
#661974 07/13/2010 1:29 AM
Can some one tell me exactly where the pedal return spring hooks? I think I have looked good but am not able to find a place. This is on a 46 1/2 ton.
Monroe McKill
3B Offline
Hy Monroe Mckill, I believe I already answered this question for you on June 25th. The tabs I referred to may have been removed, and were lost by the previous owner. They are pretty easy to replicate, basically a tear drop shape with a 3/8" hole at the large end and a 5/32" [appox.] hole in the small end, if I remember correctly the one at the base of the pedal is bent approx. 45 degrees between the two holes, so the spring can go straight to the back of the transmission, hope that helps.
