5 members (WICruiser, 55shaker, Oswald, Bill Hanlon, 1955 1 Series), 178 guests, and 1 robot.
Topics128,263
Posts1,058,348
Members48,485
#661922 07/12/2010 11:32 PM
So the mini van alternative i.e. my Suburban got her beauty treatment started this last Saturday. It's a 58 black plate CA Burb, so it's has the mandatory sun burnt surface rust patina from way to many hours under the sun in the central valley. According to the papers I found in here shes been there her whole life (got a parking permit from 1960 stuck under the head liner).
Anyways her is the pics how she looked before I started..
Before treatment front
Before treatment front 2
Tailgate before treatment
Yes she is the one with the missing parts from the tailgate frown and yes she also don't have the second or third row of seats.. I intend to make the seats from VW bus (Split screen/Baywindow) since they also have 2/3 and 3/3 seats/benches that looks vintage.. Beside if I find seats I can always change so please don't kill me..
Started with the frontend, most fun since you see some result quickly.
Front apart
The fenders are as you can see from the pics below in very good condition, just a tiny speck of rust on the passenger side one. Hehe the mini is really tiny smile compared to the chevy fenders..
Mini fenders
Inner fenders
Headlight door
The window frame and cowl are also in really good condition so very happy. So far if you exclude the tailgate only four nasty stuff has surfaced, door pillar lower inside and a some in the bottom of the front doors where the holes for the weather stipping clips are. It's very minor and I only sheared two bolts so far so it's looking good..
Windshield frame and cowl
Don't know if it's the original engine but it's a 58-61 283 according to the casting number (3756519), so at least it's from the right time frame and not a 350 from 1985 smile.
Casting numbers
Maybe someone can recognize the heat shields under the exhaust manifolds?
Heat shields
Somebody must have fixed the passenger side jump seat, but I'm happy they did and didn't junk it, now at least I have both driver and passnger seat all original less the fix of course..
Jump seat
Burbly Dyna...
PS: Yes I'm still hunting tail gate parts!! or panel doors if I can find a affordable way of shipping them...
the heat shields are original for the 283 with proper spark plug wire routing, which should go down the back and along the pan and up, being held by the slotted tabs in your pic
look for a stamped number on the protruding block pad at the bottom front of the pass side head, if it hasn't been milled off from rebuilding it will say more about the engine
<snip>
Thanks Bill!
Do you know if anyone carries those additional brackets needed to route the cables? Are they the same as on a 58 Impala?
Oh yes your 283 is blue gray is that correct? Sorry pretty new to chevy.. mostly Buick and Caddies before..
Burbly Dyna
have never seen those holders reproduced, but I'd expect to find them on any 283, truck or car, maybe on 327's as well, but after that they changed style and routing of wires
there's always debates about "correct", but the best available info says my engine color is right, and it's just rattle can "GM engine gray",
Thanks again Bill as said I'm pretty green when it comes to Chevy!!
Burbly Dyna
