1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#661643 07/12/2010 1:31 AM
does the primary wire off my distributer go to negative side of coil, and why? i have a 261-6 and i'm in the process of getting it running again and learning alot as i go. thanks for any info!!
boomers59 #661670 07/12/2010 2:55 AM
1954 Wiring diagram .
Yes, the primary wire from the distributor is attached to the negative post on the coil. Why? Other than that is what the manual says? I'm a mechanical engineer. We need an electrical expert for the why.
Hoyt
hoyt #661683 07/12/2010 3:39 AM
Because you have a negative ground system. The points ground the coil then open again causing the coil to fire.
Cletis #661725 07/12/2010 6:26 AM
it also, has to do the way the "COIL" is made internally. the windings only go one way or the other depending on if your are a positive or neg. grounded system. all our trucks are Neg. ground at this point.
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
