0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#661289 07/10/2010 5:36 PM
I have a 3100 with a 235 engine. It runs at 182 degrees even on a 100 degree day. Doesn't break a sweat. So, am I right that when I have to replace the t-stat, I should use a 180 degree thermostat? Any advantage in using a 160?
the thermostat just makes sure it doesn't run colder than whatever its value is, the rating is the temp it opens fully, a few degrees below that it will start to close - if your 235 is running around 180, that's a good thing, if you put a 160 in, it would prolly run about 160, in my experience they tend to run cold if they can
A 160 degree thermostat was an original spec (1953?).
180 will work fine.
http://chevy.oldcarmanualproject.com/chevyresto/53148.htm
i like to run 160-170 in mine even with new rebuilt engines and recored radiators. for those that have been to my place you know getting to it takes some grunt. on hot days with a load on the truck it can raise the temp to a region i dont care to see. recoring has helped tremendously.
Tim, are you sure? The way I read the specs - "fully open at 176 deg F" is a 180 thermostat.
Harold Wilson
41 Chevy 3/4 Ton
