6 members (R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, crenwelge, Gray_Ghost), 103 guests, and 0 robots.
Topics128,125
Posts1,056,341
Members48,440
#661191 07/10/2010 3:17 AM
I took the front axle off 2 years ago and I am putting everything back. I know I should have taken more pictures but.......Riddle me this Batman,
There are 6 holes on each side of the front axle. 4 are for axle bolts, one is for the leaf spring bolt head and there is a smaller one in between the axle bolts. What is it for? Does it go to the front or rear?
I don't beleive the extra hole serves any real purpose, or not as far as I can tell. What i can tell you is that it goes to the rear.
Bill Burmeister
What year and model of truck are you working on ?
1951 3100 Chevrolet
1949 3100, so...they are just holes.....there to confound me?
You got me curious, so I went out & looked at my '49 3100. Nothing in the hole but dirt. Like said before, it goes to the rear.
Scott
Thanks guys. Riddle solved then.
Are you referring to the line up holes for the leaf spring center bolt??
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
No, there is a smaller hole just below that hole. Evidently it has no purpose????????
I believe that litle hole would be for the caster shim, which has a little tit protruding from the thick side. (it is a wedge shaped shim) Looks like they were probably there to make sure the shim wasn't installed backward.
Steve
'49 3800
'52 3600
'57 3100
Gotcha.
1952 Chevy 3100
