4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
#661052 07/09/2010 4:23 PM
This project is under way - to be running by the truck's 60th birthday - and I know there is information to be gleaned on this board, on this subject, but I guess I am no darn good at searching.
The first question I have is, are there mounts available for this swap?
1951 3800
-hotshoe
Don't all the 216/235/250's have the same mounts? The 292's are different (offset), but I thought the others were the same, even up into the 80's.
The 230/250/292 are all different bellhousing and side mounts from the 207/216/235/261 motors.
The GMC 228/248/270 and 302 motors complicate the picture a little more...
Canadian built models make it even more complicated. What truck do you have and what motor are you dealing with?
I have a US-built 3804, a 1951 one-ton pickup, which is getting a 1981 250. The engine is from a fleet-spec 1/2 ton. A 1981. Sorry, I thought that was clear from the title.
1951 3800
-hotshoe
Sometimes follow-up questions need to be asked to help other posters understand the context. That was the case here as far as I'm concerned.
The series of motors that includes the 250 all use the same bell-housing pattern at the rear and mostly the same engine mounting. The 292 is a little different so we'll ignore it for now.
The 250 can be mounted where the 230 came out and actually the engine mounts and bell-housing are the same as a side-mount Chevy V-8. You don't have to worry about the steering because the motor is narrow like the original six, and the mount kits you can buy for a V-8 make the swap straight-forward.
The mounts are completely different from the early Chevy/GMC motors.
But I'll need the 250's bellhousing because the 216's won't work, right?
Will I still be able to use the stomp starter? How about the drum on the back of the old tranny?
1951 3800
-hotshoe
Right. 1980 might not be the ideal choice but you will need a post-'54 Chevy V-8 type bell that bolts between the transmission and the block.
I hate to label things impossible, but without some modification and fabrication you won't be able to use the stomp starter.
Should be no problem.
You can fabricate a fake stomper that will appear normal to the casual observer. The project involves a push-button starter switch mounted below the floorboard and the top part of the stomper pedal attached to a hinge or sleeve that allows you to push the button with your foot. The pushbutton is wired between the ignition switch and the starter solenoid so it's hot with the ignition in the "on" position, just requiring a push to complete the circuit.
All useful information, thank-you both. Last question: OldSub, you say 1980 may not be the ideal choice of bell. Why?
1951 3800
-hotshoe
