3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
Sir Searchalot
Sir Searchalot
Did a search, didn't see. Which way does the column remove. Will it pull down thru after wheel and shroud are removed? and of course the box unbolted, arm removed.
Bartamos,
Raise front end, and you will be able to guide it out from below. It will help if you have someone in the cab helping with guiding out the column.
Richard
58 3104
Sir Searchalot
Sir Searchalot
Got it thanks, how much is it worth to sell?
