1 members (Steelonsteel),
44
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Folks -
Well, we got the truck home last night, dropped her off at my In-Law's ranch so we can drive it around while we are "fixin to" get it going and all....
Confusion on engine and chassis ID. The number stamped on the pad to the rear of the dist and above the starter reads "FO 616A". I checked the engine ID leads here and NOTHING(at least as I can see) matches. Any ideas? Same goes with the engine casting numbers. The casting number on the side of the block below the dist is GM 22 (fairly large) then forward of that 3763 6. Additionally, there is a casting number by the starter of "F 141" and one ahead of the distributor, just above the oil pan flange that reads "37696716". On the Cyl head between 2 & 3 exhaust port it reads "3836848 GM 24"
Can anyone help me with this one?
Thanks!
John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Could the 37696716 code have been 3769716 (58-62 235)?
3836848 was used on 56 and newer 2335 heads (and on replacement heads after 1956)
F 141 might be the date casting code: F = Jun 14 = 14th 1 = 1961
