4 members (HareCanvas, Steveoreno, Waveski, stlcardinalsguy), 109 guests, and 5 robots.
Topics128,184
Posts1,057,266
Members48,467
Does anyone know if the 55-59 panel/burb roof is the same shape and width as the truck? I am working on an extended cab project and am thinking of using a roof section out of a panel in a truck. Also if anyone has a junk/parts panel/burb with a good roof section, see my ad in the parts wanted area. I really do not want to fab a roof skin from scratch. I just found out I have another child on the way and an out of room in a reglar cab truck
thanks
Shane
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
no it's not the same, different crown altogether because of the longer roof so the panel roof is slightly taller
thanks for the response. I guess I will have to section in pieces from two trucks or start making a panel. If only I had an English wheel and knew how to use it. Oh well at least I was able to cut up some doors for the side panels and window openings.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
