3 members (78buckshot, baldeagle, Rusty Rod), 109 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#660623 07/08/2010 4:08 AM
I have a 65c10 with 283v8 2bbl. when I removed the carb. I realized one stud was missing. after further inspection, there is a little rod where stud should be. could this be a rusty and rotted stud? Ive never seen a 3 stud carb. with a 4 hole pattern. any help would be great, I'm rebuilding the carb. tomorrow. Thanks Brett
It sounds like you've got a rusted or broken-off stud. A little Kroil and some heat, plus a pair of vise grips will probably let you unscrew it, but don't break it off flush with the manifold or you'll have a devil of a time getting the rest of it out. Some of the older intake manifolds had a heat riser passage that exposed two carb mounting studs to exhaust gas, and they rotted off pretty regularly.
Jerry, I think you are correct. I'll try in the morning, the other side is rotting also.
Better change them both while you're in the mood, and if you can get a stainless steel stud to use as a replacement, it will last longer.
Carburetion specialist
Change them all!
If one does twist at or below the surface of the manifold, weld THROUGH a nut sitting on top into the twisted stud below. Prior to welding, disconnect any electronic gizmos you may have on the engine. Once you have the nut welded on, very easy to withdraw the stud.
Jerry - no offense, but I disagree on recommending stainless. Yes, it may last longer; but the friction is different, thus the tightening torque is different. A somewhat difficult "carburetor issue" is a vacuum leak at the intake caused by a loose carb to intake nut. Not saying stainless should not be used; but if used, the user needs to understand both positives, and negatives.
Jon.
The Carburetor Shop
Good point, Jon. Sometimes I forget that everybody doesn't have 50 years' experience to draw on concerning installation torque, anti-seize compound use, etc. I just naturally consult the appropriate torque tables, or use self-locking nuts when I'm making that kind of modification. Thanks for the reality check!
Jon and Jerry thank you for the info. the welding the nut on idea makes alot of sense, never would have thought of it. Thank you Brett
Keep the welding a nut to it idea in mind whenever you break a bolt or stud. It not only gives you a good hex to get a grip on, but the heat of the welding helps break the nut loose.
